battery draining by plughing in the GPS
i was using a GPS when traveling to Oman and slowly i started noticing that the battery is getting low when all the lights started getting dimmer
so i unplugged the GPS and lights were brighter which indicated that the batter was doing good so i reconnected the GPS and the same thing happened again.
any reason to this situation
Do you see any red color battery icon in dash?
If yes that means battery is getting weak or not charging enough. If no icon and car starts perfectly everyday, then i wont bother much unless the battery fails. It may be that battery is getting weak or not fully charge SOMETIMES. And once it charges good it will be fine.
