GhalibDXB Posted April 10, 2019 Share Posted April 10, 2019 Hi, if anyone can tell what is the Minimum/standard distance between front tyres to the front bumper, as my tyres are touching front bumper if I am going above 80 KMPH and also while turning. 1 Link to comment Share on other sites More sharing options...
desertdude Posted April 10, 2019 Share Posted April 10, 2019 You're probably running oversized tyres, hence the rubbing. 2 Link to comment Share on other sites More sharing options...
GhalibDXB Posted April 10, 2019 Author Share Posted April 10, 2019 It was after my last desert drive. I think of going to some workshop to check. 2 Link to comment Share on other sites More sharing options...
Srikumar Posted April 10, 2019 Share Posted April 10, 2019 This is not the issue of oversize tyre. This is a common problem with the Pajero after a desert drive. You had hit the front bumper and it has moved in a little. Since it's made of fiberglass you cab just pull it out. No point spending money in a workshop. If you plan do offroading i suggest to remove the lower plastic black lip (where you have circled). There are only two bolts and would help a lot 8 Link to comment Share on other sites More sharing options...
GhalibDXB Posted April 10, 2019 Author Share Posted April 10, 2019 Wow, Good to know that. I will try now. Thanks alot. 👍 1 Link to comment Share on other sites More sharing options...
