topgear Posted August 25, 2020 Share Posted August 25, 2020 My FJ will reach 100k km in a approximately another 2-3 weeks. The car is just out of warranty and also service contract. I shall appreciate the following information (not specific to FJ only) but mainly for Japanese 4WDs: 1) what is advised/needed to be done for the 100k km service? I was advised to find out more information and be prepared should certain service advisor starts to 'recommend' all sorts of repairs or replacement since there is no service contract and warranty. 2) where do you do it? 3) estimated costs? 1 Link to comment Share on other sites More sharing options...
Barry Posted August 25, 2020 Share Posted August 25, 2020 As per Toyota, 100k service includes Check installation of driver’s floor mat Inspect and adjust all fluid levels Inspect wiper blades Replace engine coolant Replace engine oil and oil filter Rotate tires Visually inspect brake linings/drums and brake pads/discs Additional Maintenance Items for Special Operating Conditions Driving on dirt roads or dusty roads: Inspect ball joints and dust covers Inspect drive shaft boots (4WD) Inspect engine air filter Inspect steering linkage and boots Lubricate propeller shaft Re-torque propeller shaft bolt Tighten nuts and bolts on chassis and body Driving while towing, using a car-top carrier, or heavy vehicle loading: Lubricate propeller shaft Re-torque propeller shaft bolt Tighten nuts and bolts on chassis and body 2 2 Link to comment Share on other sites More sharing options...
