kaifrish Posted July 18, 2011 Share Posted July 18, 2011 I get a rumbling noise when I drive and according to the mechanic the inside boot on the driver's side CV joint has separated, he has given me 2 options that is to get it replaced or repaired and i need a second opinion on this please thanks Link to comment Share on other sites More sharing options...
iroc Posted July 19, 2011 Share Posted July 19, 2011 If you are already having a noise then the CV joint has run dry and is damaged. Most likely you would be having vibration under acceleration. So you are better off changing the drive shaft rather than fixing the boot. Link to comment Share on other sites More sharing options...
joe Posted July 19, 2011 Share Posted July 19, 2011 I second to Iroc, boot should be completely sealed and loaded with grease so that joint wont run dry. If once boot tear and car run for a while or if you are in doubt then its better to change to save the hassle and labor cost for second time. Link to comment Share on other sites More sharing options...
