Rizwanm2 Posted September 19, 2020 Report Share Posted September 19, 2020 Hi Guys, as all of you guys would agree maintaining correct tyre pressure is an utmost priority in off roading. There are lot of cheap solutions out there to monitor each tyre pressure in real time. some are just simple as replacing the valve cap, i found below listings in Amazon. https://www.amazon.ae/s?k=tpms&ref=nb_sb_noss There are mixed reviews in Amazon on each product. does anyone have hands on experience on this? what is your opinion? 1 Link to comment Share on other sites More sharing options...
Frederic Posted September 20, 2020 Report Share Posted September 20, 2020 14 hours ago, Rizwanm2 said: Hi Guys, as all of you guys would agree maintaining correct tyre pressure is an utmost priority in off roading. There are lot of cheap solutions out there to monitor each tyre pressure in real time. some are just simple as replacing the valve cap, i found below listings in Amazon. https://www.amazon.ae/s?k=tpms&ref=nb_sb_noss There are mixed reviews in Amazon on each product. does anyone have hands on experience on this? what is your opinion? I don't have much experience with these things, but i am afraid the cheap solutions will only bring more confusion, and might not properly show the difference between 14 and 12psi, which is a big difference while offroading. On the other hand, 70AED is not that very expensive so it might be worth testing them. 1 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Barry Posted September 21, 2020 Report Share Posted September 21, 2020 There are systems available which involve replacing the the original TPMS sensors. The new sensors send a radio signal to a dash mounted display which allow you to monitor tyre pressure in real time from inside the car. https://www.amazon.ae/KKmoon-Pressure-Monitoring-Security-Internal/dp/B07W5GB125/ref=asc_df_B07W5GB125/?tag=shoppingstd03-21&linkCode=df0&hvadid=387653097570&hvpos=&hvnetw=g&hvrand=3332161968380573610&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=1000013&hvtargid=pla-825589466563&psc=1 Other similar systems are available where the sensor screws onto the existing valve stem. This means you don’t need to break the tyre bead to fit them but they may have leakage issues if sand gets into them. 1 Link to comment Share on other sites More sharing options...
