Hisham Masaad Posted February 18, 2021 Share Posted February 18, 2021 Good morning I see some people carry with them sand traction boards, but can can say never with Carnity group. Opinions please, and apologies if discussed earlier, since I didn't check. 1 Link to comment Share on other sites More sharing options...
Frederic Posted February 18, 2021 Share Posted February 18, 2021 Good morning @Hisham Masaad There are different models in the market. You have the flexible roll-up tracks like this: And then you have the solid models like this: * Maxxtraxx * ARB * AOR * Chinese Dragon Mart copies. My opinion: The flexible ones i have seen in action a few times, but never seen them working in sand. I do not believe they are worth it. The solid ones however are a nice item and when used properly, can get you out of tricky spots IF you also understand the essentials about self-recovery and use the blip-blip method instead of flooring the throttle. There will be difference in rigidity/flexibility between the professional models like ARB and Maxxtraxx vs the cheaper Dragon Mart models, but how less effective they are i do not know. Have a look at below video. I happen to know the guy and i discussed this event with him after seeing it online. As he likes going for long overlanding trips, he got stuck on a salt flat and was able to get himself out with these boards: I know that a wet sabkha is totally different from dry desert sand, but i have seen @frederic demolder using his boards a few times, and maybe it was not always a success, but sometimes it was just the little 5% of traction he needed to wiggle the car out. As i said you need to use them with caution so they don't fly out when you rev to hard. Use the blip-blip method and put at least two boards on each wheel that has no traction. Be gentle with the gas and just try to find a bit of traction. 1 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Hisham Masaad Posted February 18, 2021 Author Share Posted February 18, 2021 Thank you @Frederic for the same. Appreciated Link to comment Share on other sites More sharing options...
