Air Filter Tights/Stocking/Shower Cap Trick :)
Zed
Well we know we're supposed to knock gently the air filter after _EVERY_ drive to shake off the sand, but any trick to prolong that Procrastination helps to extend that mundant task to 3-5 drives later on 😅 . So what do you guys do to cover your air filter from sucking up too much sand? A filter for the air filter you may say! Today I'm gonna test if covering up the air filter with lady's tights/stocking will degrade the performance vs filtering much sand worth-it-or-not discussion. Joining @Anish S's Fewbie drive and let's see if this hack will survive the drive and keep much sand out or not 😁
See pics below if i'm talking gibberish to you 😹
Photo 1: air filter "naked", this much sand for a newbie drive:
Photo 2: let's put some filter for the air filter 😁 , using lady's stocking but a showe cap will also do i guess...
Hello Zed, i hope you are testing this first on normal roads, probably with some stints of hard acceleration ?
As the suction picks up at high revs , it should not collapse, or come off its securing end and roll up in the middle ?
just some loud thinking.
Yups i'll be driving from Abu Dhabi to Dubai for 2 hours @ 140 km/h so that's already some testing before coming to the desert 😁
I suggest you to use original filter of your car instead of this aftermarket one. These are more prone to suck sand in to the Engine.
3485612A-E574-4E81-9A58-365288D4B1F4.jpeg.73031427b201543ec3c332e8679a21fb.jpegJust make sure your stockings don’t come falling off and ending up in the face of the one sweeping the convoy !
  • Haha (+1) 4
Unfortunately this came with the package when i was doing custom headers & exhaust... but i still have the original air filter housing... will try it out for a year before going back to stock 😂
Edited by Zed
@Frederic i'll be gentle today, especially since your car was subjected to additional 2 hours of Abu Dhabi heat while loaning to @Gaurav bhai, hope he told you how that story went 😂
My advise, don't use stocking cover please. These YT hacks and stunts are most dangerous stuff you will ever do.
It starts with 1 fake claim of X additional HP with free flow filter and to achieve that "unknown" "unsaid" "non-tested" fictional gain owner tend to do 100 wrong moves.
Totally agree with @sertac to switch to original stock dry paper filter, and clean after 4-5 drives easy (as u asked above), as factory filter box has enough space underneath to hold 100 - 200 grams of sand, even half a kg (I guess).
Many have busted their engine (incl. me) for these fictitious gains, that will only come when you also put chip + 100 other mods + 200 star aligned in one line.
thanks, always good advice bhai 👍🏻
