ramsom Posted January 23, 2011 Share Posted January 23, 2011 i have a 2008 escort and need to replace the cam shaft sensor. can somebody give me a step by step instructions. thanks Link to comment Share on other sites More sharing options...
abrahim Posted January 24, 2011 Share Posted January 24, 2011 The cam sensor is somewhere on the cylinder head and should be easy to replace. If you look at the lower right of the valve cover the cam sensor is in the side of the head just below the valve cover. It's small black and has two wires going to it. Hope ur cam timing isnt off, what code u got??? Link to comment Share on other sites More sharing options...
