jeet Posted June 2, 2011 Share Posted June 2, 2011 when the coolant started going down the service adviser said that the radiator has a leak that i cant see and he can. are there any other reasons for the coolant vanishing? thanks Link to comment Share on other sites More sharing options...
salah Posted June 5, 2011 Share Posted June 5, 2011 Only leak can reduce the coolant level, i hope leak is external and not internal. As internal leak is from engine head gasket and that is one expensive to fix to change the head gasket. If external, it cud be anyway from small to medium fix like hose leaking, radiator core leaking, thermostat etc. Link to comment Share on other sites More sharing options...
jeet Posted June 16, 2011 Author Share Posted June 16, 2011 thanks Link to comment Share on other sites More sharing options...
