AhmadTaha1988 Posted April 8, 2023 Report Share Posted April 8, 2023 2023 Sahara all stock except for 2.5 inch lift. In the worst times where I actually need power the car decideds to kill power. I see the owners manual mentions engine Tourque Reduction as a safety feature. Anyone has this problem? I use the onboard switch to kill TC/ESC. Driving in 4H on sand, a couple of times lost power on the side of a dune leaving me in a risky situation.... I this something a tunning or a chip can undo? Is it just my car? 2 Link to comment Share on other sites More sharing options...
Gaurav Posted April 9, 2023 Report Share Posted April 9, 2023 It seems a flaw that the warranty should handle and fix or at least explain. If its completely stock and nothing has been tinkered with Engine Management System, then you should seek dealership help. 1 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Benjamin Posted April 10, 2023 Report Share Posted April 10, 2023 @AhmadTaha1988 That is a strange issue, although I have lost power usually when climbing and sometimes on the side of the dune, after a few drives, the onboard computer got use to the new driving style and the car consistently planted power down on dunes & roads. If your car is an automatic try using Tiptronic you'll find yourself using 2&1 to climb and 3 for cruising flatter areas. still might be a good idea to take @Gaurav advice on the situation though. 2 Link to comment Share on other sites More sharing options...
Looper Posted April 10, 2023 Report Share Posted April 10, 2023 A question would Be to know if you are a new/old Jeep driver and are you driving a JL for the first time. normally a new car computer will take some time on the new driving conditions. Apart from that climbing tall dunes will take skill full utilisation of triptronic gear shifting and acceleration that You will learn it over time. 2 don't drive like its your last one. Link to comment Share on other sites More sharing options...
AhmadTaha1988 Posted April 10, 2023 Author Report Share Posted April 10, 2023 New driver. Waiting for first Newbie drive so I can join. Maybe ill let s more experienced person drive the car and check it out for me. Could be the way im driving! 2 Link to comment Share on other sites More sharing options...
Looper Posted April 10, 2023 Report Share Posted April 10, 2023 Larger dunes in swehan and badayar would need you to manage the climbs. In the Newbie drives, the car would manage the gear shifting etc. automatically but it need a little time, not much though and also your driving technique will change as you drive more in tune with the capabilities of the car. Give it a few drives, for both of you & your car to understand each other. 3 1 don't drive like its your last one. Link to comment Share on other sites More sharing options...
