dashboy Posted October 7, 2023 Share Posted October 7, 2023 Hi All, I have a 2023 Baleno GLX that has the non-silencing 120 kph speed chime. I have been in deep discussions with UAE Suzuki over this and trying to get a software update to remove this. The dealer will offer a silence all chimes which is a bad decision as it mutes all chimes including safety items. I have declined this option. When I was buying this car, I was refused a highway test drive and only allowed on side roads at max 70 kph. I never knew that it would beep none stop when above 120 kph!! I'll keep you posted on the outcome. 1 Link to comment Share on other sites More sharing options...
Gaurav Posted October 9, 2023 Share Posted October 9, 2023 Find a source of the chime under the steering wheel and disconnect the wire, or I have heard a few mechanics punching that speaker with a screwdriver. Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Frederic Posted October 10, 2023 Share Posted October 10, 2023 10 hours ago, Gaurav said: Find a source of the chime under the steering wheel and disconnect the wire, or I have heard a few mechanics punching that speaker with a screwdriver. that chime is probably used for other safety related alarms as the poster stated. Another option might be to put a small switch inbetween the chime light, so whenever you hit the highway and plan to drive +120km/h you could disable the chime by flicking that switch. 1 1 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Gaurav Posted October 10, 2023 Share Posted October 10, 2023 4 hours ago, Frederic said: that chime is probably used for other safety related alarms as the poster stated. Totally agree buddy, I missed that completely. Sharing some old car hacks, forgot it's 2023 already. 2 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
dashboy Posted January 21, 2024 Author Share Posted January 21, 2024 The speed chime cannot be silenced by cutting a wire or installing a switch as this will deactivate other key safety warning sounds such as the seat belt. The design of the 120 chime, as I was told by Suzuki, is a EEPROM. I need the wiring and ECU layout with pinouts to see if it can be done. Does anyone have these manuals? 2023 Baleno GLX with K15B motor. Link to comment Share on other sites More sharing options...
