2024 LC70 3 Door
What am I doing wrong here?
Out of interest was looking at the specs from al futtaim for the new LC70 3 door.
The HP is at 228 and weight at 2600kg.. giving it around mid-80s using Gaurav's formula below putting in well in the borderline performance category.
Thats a lot heavier than my 5door pajero... can these figures they are publishing be right? I would have expected a lot better from a 4L v6 on a short body like that.
  • WOW (+2) 1
5 minutes ago, Gaurav said:
It's gross weight with a full fuel tank and 5 passengers.
Kerb is around 1850-1900 kgs.
Ah that makes a lot more sense.
Thankyou🙏
58 minutes ago, Gaurav said:
I expect it might be a tiny difference to this as think this is previous model (2024 has 6 speed auto trans only), but imagine its largely the same weight wise. This def beter for the ballpark figures.
Thanks for the info link @Gaurav
@PETELCZYC PAJERO - lukeis dreaming about getting LC70 now :)
The only issue is see with them in stock version is that the rear axle is more narrow than the front axle, which makes it a bit tricky for off-roading on higher levels (more prone to roll over). On 2door this is especially a topic.
From what i have seen most off-roaders solve this by changing the rims to a wider off-set in combination with spacers to have a nice wide footprint.
Apart from that.... LOVELY and LEGENDARY offroader.
  • WOW (+2) 1
dreams dreams dreams.
does have a cool retro look as well. 😍
Still tooooo heavy imho for a SWB
Not really, it's light compared to others. Patrol SWB is 2100, Pajero SWB is 1950.
Mine at the weigh bridge was 2200 (Gross).
  • WOW (+2) 1
