edy Posted July 18, 2012 Report Share Posted July 18, 2012 is the engine oil topped like the coolant or is it filled once when the maintenance is done. dont have any problems this is just a curiosity question. thanks Link to comment Share on other sites More sharing options...
rusalracal Posted July 31, 2012 Report Share Posted July 31, 2012 if engine oil looks low then it means that there is a leak. the oil should be emptied out and check the leak. Link to comment Share on other sites More sharing options...
yahya Posted August 28, 2012 Report Share Posted August 28, 2012 engine oil in general conditions is checked regularly that it isint low and when you get the maintenance the oil is changed. if the engine oil looks low that means its leaking. Link to comment Share on other sites More sharing options...
