tarik Posted March 7, 2014 Report Share Posted March 7, 2014 Hey Guys Please discuss the possible faulty warning lights that popped up on the panel and what you did about the same. Link to comment Share on other sites More sharing options...
ethan Posted March 10, 2014 Report Share Posted March 10, 2014 faced only two warning lights in my car. One was Check engine warning light. I took my car to the garage and there was a fault in the emissions. Second was Oil pressure warning light. This is was bit serious because the engine was not receiving the proper oil pressure. I took it to the garage immediately and they repaired the issue. Thanks! Link to comment Share on other sites More sharing options...
mukesh Posted March 10, 2014 Report Share Posted March 10, 2014 I faced brake warning light once. When you get this warning light just check the parking brake. If you did not release the parking brake, this light pops up. But if you already released it, they the problem is serious. The brake system may be suffering from a serious hydraulic problem which makes it unsafe to drive the car on the road. Please dont ignore this warning light. Link to comment Share on other sites More sharing options...
alikhan Posted March 10, 2014 Report Share Posted March 10, 2014 I recieved service warning light. It was because of the oil change. Next day i went to the service center and changed the engine oil. Link to comment Share on other sites More sharing options...
tarik Posted March 15, 2014 Author Report Share Posted March 15, 2014 I faced a temperature warning light once. It was kinda serious. I opened the engine of the car for 30 minutes and let it cool down. The level of the coolant was very less and thus next day i went to refill the coolant. Link to comment Share on other sites More sharing options...
