Sunday Morning Fewbie Drive - Makhoola play ground - Abu Dhabi - 23 AUG 2026
_luke_
DRIVE DESCRIPTION
A short, focused Fewbie-level morning drive through Makhoola, with the emphasis firmly on ridge riding, clean lines and maintaining momentum..
With the summer temperatures climbing quickly, we’ll keep the drive to approximately 2.5 hours and aim to finish before the heat becomes too oppressive.
DRIVE DETAILS
Level:  Fewbie and above
Meeting time: 06:00 (SHARP - Without any exceptions)
Meeting Point: https://goo.gl/maps/pYfkc7voUa2yxRGM8?g_st=ac
Meeting Coords: 24.2645001, 55.1094439
What to bring along: Loads of water, snacks (for yourself), smiles, enthusiasm and willingness to learn.
Approximate finish time: 09:00
LIMITED SPOTS AVAILABLE
  • This drive is limited to 8 cars only. RSVP will close on Saturday 12:00
  • If the RSVP is full, you can add your name to the waitlist, once someone drops, you will be moved to the RSVP list.
  • Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others.
  • Repeated no-show members after RSVP will have their account suspended for a month
Drive Briefing.
We will enter on the western side, driving along some sand track, before entering some dunes with a bit of vegetation.
After picking our way through here we will enter the BLUE zone where we will spend most of our time playing around on the ridges, finding some sidies and maybe testing time short but tight technical dunes.
Depending on the heat and the vibes, we will either push on and attempt some higher dunes before exiting at the east side of the camel racing circuit, or we will head due south and exit at the Tilal Resort.
