zeeshan7 Posted January 27, 2011 Share Posted January 27, 2011 Someone tell me how to reset SRS light 2007 civic gulf specific... Link to comment Share on other sites More sharing options...
rohitkr Posted January 27, 2011 Share Posted January 27, 2011 SRS light comes after some probem, and if you have fixed the problem and just wanted to kow how to reset the warning light follow the instruction. If u havent repaired the problem even after this light goes, it might or might not come back. Under steering there is fuse panel, open it out and remove yellow color SRS plug (poer connector). Take small wire and stick each end to each terminal and turn on the ignition (dont start). Let SRS warning check the circuit and will go off in few seconds. Once it goes off remove wire and fix the plug back in pace and start the car. Link to comment Share on other sites More sharing options...
zeeshan7 Posted January 29, 2011 Author Share Posted January 29, 2011 Thanks Rohit for your concern... yes i already did before but AirBag light still on... actually im 2nd owner of this car.. the car was accident by first owner from front side.. obviously airbag was open.. and they fix new bumper etc... but airbag light still on.. do tell me if u have another solution... thanks... Link to comment Share on other sites More sharing options...
zubs Posted January 29, 2011 Share Posted January 29, 2011 Get new air bag buddy, if Rohit solution isnt working that means airbag is not healthy and cant deploy in case of accident. After u fit new airbag either u can turn off that light with OBD II connector thru computer or by Rohit solution. Link to comment Share on other sites More sharing options...
