what is triangle light
rafool
Vehicle stability assist activation indicator,:it tells you either the VSA is turned off or that the VSA is malfunctioning.If it is flashing it means the VSA is working at that moment and doing its job.
If ABS, VSA and yellow triangle lights came on, then that means its a ABS modulator, Its a known fucking problem with Honda abs modulator and in many case honda fix this by themselves for free. If not you will cry as it might cost u over 6k aed.
In some cases if this light come and go, it also be voltage fluctuation from battery which cause this. So if u got this light recently, try disconnect and reconnect battery may solve ur problem.
