Tires going flat easy?
I have a 2003 Honda Accord, just for reference. I'm not sure this is even a Honda or Accord specific issue, but here goes:
My tires keep going flat. I have bought new tires, got an alignment, rotated the tires, and they all will continuously go flat.
I can't find anything other than 'get an alignment' when I've already done so. What do you guys think it could be?
Could be an issue with the tire valves or maybe your rims could be damaged
Ah, you may be right on the rims, I'll have to check that. I came too close to a curb when parking once and the rim does have visible damage, although it looks more like scratches. I'll have to check and see if it's more than just the scratches. I thought it was superficial. Didn't think it would really have an impact.
Thanks a lot!
it could have quite an impact. Damage to the rims can cause wheel imbalance and alter alignment and camber settings leading to steering vibration while driving. Its not very common that it causes leaks but such a probability cannot be ruled out.
Always glad to help
Wheelocity Garage :)
  • 1 month later...
  • 2 weeks later...
  • 1 month later...
