hassanh Posted August 3, 2012 Report Share Posted August 3, 2012 gear of the car is not changing to 4 wheel drive any one can please tell me what is causing this and how or what i can do to fix this? Link to comment Share on other sites More sharing options...
japdi Posted August 13, 2012 Report Share Posted August 13, 2012 before taking this anywhere go to Rashidya Opposite Festival City there are good garages in a line and will see the problem. dont delay and dont experiment. Link to comment Share on other sites More sharing options...
rohitkr Posted August 28, 2012 Report Share Posted August 28, 2012 running and 4x4 turned on disconnect the vacuum line at the hub and check the vacuum suction If there is no suction then check the vacuum lines from front wheel hubs for damage If you have a good vacuum it may be worn so take them off, clean, and degrease Link to comment Share on other sites More sharing options...
hassanh Posted March 6, 2013 Author Report Share Posted March 6, 2013 there is a new problem with my HRV i have the rear tires that get locked for a min, i have to switch the car off and on again and then its working. why is this happening Link to comment Share on other sites More sharing options...
