navkirt Posted April 22, 2011 Share Posted April 22, 2011 where is the fuel filter located in 1999 Galloper thanks Link to comment Share on other sites More sharing options...
neil Posted May 8, 2011 Share Posted May 8, 2011 fuel filter is located on the frame rail, passenger side of the car near the rear tire. Just clamp off the lines on boh sides of the fuel filter so fuel doesn't go all over the place then remove the one bolt holding the fuel filter in place. Remove the fuel lines and put your new filter in place. Attach the fule lines, bolt the filter back in place and remove the clamps. I hope that helps. Link to comment Share on other sites More sharing options...
