munna Posted June 3, 2011 Report Share Posted June 3, 2011 where is the speed sensor located in my car? thanks Link to comment Share on other sites More sharing options...
hameed Posted June 5, 2011 Report Share Posted June 5, 2011 If speedometer isnt working, then check fuse no: 16 and 17 first. If they are fine then it cud be sensor. In your car there are two sensors. One is roughly between the master cylinder and the coil pack on the transmission. Connector C09 for a 6 speed and C10 for a 5 speed, but they are both in the same spot. And another one behind the transmission access from below the car. Link to comment Share on other sites More sharing options...
munna Posted April 8, 2013 Author Report Share Posted April 8, 2013 How much should i spend to change the cruise control. Link to comment Share on other sites More sharing options...
raif Posted July 3, 2013 Report Share Posted July 3, 2013 had my lexus speed sensor changed for which i spent 500 aed. Link to comment Share on other sites More sharing options...
munna Posted July 6, 2013 Author Report Share Posted July 6, 2013 250 from ajman thanks Link to comment Share on other sites More sharing options...
