abhai Posted June 22, 2011 Share Posted June 22, 2011 the pump that sprays the fluid on to the windscreen for cleaning is not working and is leaking how should it be fixed? Link to comment Share on other sites More sharing options...
mandeep Posted June 26, 2011 Share Posted June 26, 2011 It must be leaking water from hose or connection as the jet on hood is blocked. Its the most common stuff. Pluck the jet with needle and see if it still leak. Then change the wiper pump, its cheap around 100 - 200 dhs only. Link to comment Share on other sites More sharing options...
