tim Posted March 20, 2011 Report Share Posted March 20, 2011 i want to know the location of my fuel pump please a diagram would help as well thanks and yes it is a 2008 model Link to comment Share on other sites More sharing options...
albert Posted March 27, 2011 Report Share Posted March 27, 2011 -fuel pump located under rear seat (right side looking forward ) -working inside the car lift the rear seat -Pull up rubber grommet which cable goes through -remove circular steel cover plate -disconnect mutliplug on top of pump -unscrew bezel using hammer & punch -Pull up pump from tank -replace with new pump ensuring that rubber seal doesnt get kinked -replace bezel -connect mutliplug and test before replacing steel cover -Ensure no leaks, even take car for a ride to ensure no leaks -if tests ok then replace steel cover and grommet, & seat. should take about 30mins taking you time. Link to comment Share on other sites More sharing options...
