fermi Posted May 16, 2012 Share Posted May 16, 2012 when changing bearing do all 4 of them have to be changed. After feeling some sort of vibration and noise i have been advised to get the front bearing changed. what should i be doing Link to comment Share on other sites More sharing options...
asgar Posted May 20, 2012 Share Posted May 20, 2012 changing the bearin is one big work which may take you entire day almost. what i suggest is change all the bearing as this is a wear and tear part of the car and a very important too so if you are going to pay for the labor might as well make good use of it. Link to comment Share on other sites More sharing options...
qureshii Posted May 24, 2012 Share Posted May 24, 2012 Wheel bearing is most important and easily ignored parts of your car. When they start to fail there are few signs that you can notice in your car will make a grinding sound that will be so severe that you will feel through the floorboard or steering wheel. If you hear a Bearing noise then the bearing should be changed as soon as possible. Most of the time the rear bearings should be changed. good luck Link to comment Share on other sites More sharing options...
