InfinitiDubai Posted August 27, 2011 Share Posted August 27, 2011 Infiniti Scheduled Maintenance Procedures Rotate and Inspect tires Inspect Brake calipers, pads & rotors Inspect Brake lines & cables Inspect CV-joint boots & driveshafts Inspect Differential gear oil Inspect Driveshaft boots & propeller shaft Inspect EVAP vapor lines Inspect Exhaust system Inspect Front suspension ball joints Inspect Fuel lines & connections Inspect Steering linkage Inspect Suspension components Inspect Transfer case fluid Inspect Transmission fluid Replace Air filter Replace Brake fluid Replace Cabin air filter Replace Engine oil & filter Replace Spark plugs Link to comment Share on other sites More sharing options...
wizard Posted September 15, 2012 Share Posted September 15, 2012 i was about to ask this and just looked around the website and found this information. thanks Link to comment Share on other sites More sharing options...
