tarmun Posted November 15, 2011 Report Share Posted November 15, 2011 How do u change the spark plugs? can i get instructions? Link to comment Share on other sites More sharing options...
sharmaa Posted December 21, 2011 Report Share Posted December 21, 2011 First remove the engine cover. Then remove the sparkplugs electroinc igniter on top of spark plugs. Igniter is fixed with 10mm bolt and then pull out the spark plug wires and the spark plugs are inside the hole... then remove the spark plug with normal spark plug socket. This setup is also known as coil on plug setup. Link to comment Share on other sites More sharing options...
Shahidbaig Posted January 22, 2012 Report Share Posted January 22, 2012 Has any one used platinum spark plugs for long life and better perfoirmance? Link to comment Share on other sites More sharing options...
tarmun Posted February 3, 2012 Author Report Share Posted February 3, 2012 shahid i got the platinum ones as one of my friend already did and he said they are the best but a bit expensive. Link to comment Share on other sites More sharing options...
