raielp Posted January 11, 2012 Report Share Posted January 11, 2012 anyone tried to change their stock lights bulbs to HID conversion set with ballast by themselves or a mechanic ?i can seem to remove the stock bulb from the socket on the low beam Link to comment Share on other sites More sharing options...
KiaDxb Posted January 11, 2012 Report Share Posted January 11, 2012 It requires bit of experience in cutting and fixing back exact wires so that ballast can be used to light the HID, if you know the diagram and confident in doing, give it a try. Link to comment Share on other sites More sharing options...
raielp Posted January 11, 2012 Author Report Share Posted January 11, 2012 thanks basim: so the issue here is to cut the wire from the stock OEM and connect it to the HID wires. although i did have tried converting an H7 bulb to HID set but those set did not need of cutting wires, where the bulb can easily be removed and the HID wire kit can easily be inserted into the socket as i did on my sorento before Link to comment Share on other sites More sharing options...
