Massimo Posted August 23, 2011 Share Posted August 23, 2011 Where can I get a (used) radiator for a LR Discovery TL4. Link to comment Share on other sites More sharing options...
nutbolt Posted August 26, 2011 Share Posted August 26, 2011 Sharjah scrap yard is a best bet. If you cant find one. Better consider changing the core of the present one from any good half way decent radiator shop in sharjah. As it comes pre made to exact size and this mechanic just need to remove and open radiator to slide those cores. May be 3 hrs job and 100 dhs labor for changing cores. New cores may cost you 500 dhs - 1000 dhs depending on cooper or aluminium you want and whether 2 core or 3 core setup you want. Link to comment Share on other sites More sharing options...
nutbolt Posted August 26, 2011 Share Posted August 26, 2011 This is how radiator cores look like. You will spend less and get better quality work done and make sure this radiator build up will last longer than used one. Link to comment Share on other sites More sharing options...
