Key wont turn
Hello... I hope someone here can help me out. I have a L322 2005 Range Rover HSE
I went to start my car this morning and the key just wouldn't turn... the steering wheel is of course heavy but the locking mechanism isn't working either (meaning I can turn the steering quite a bit with a little power). The battery is ok since the stereo and other features still work. I read on some forums that it might be the ignition key assembly as a whole that will need replacing... I'm hoping its something a little less costly.
Any ideas? Even towing it is problematic as I can't get the gear into Neutral.. any ideas on how to put it manually into Neutral?
Thanks
Ahmad
  • 2 weeks later...
Hi Ahmed, wondering if you figure out the stuff by yourself...?
It seems really tricky situation you went into, what happened and how did u solved it? Good for knowledge sharing
  • 1 month later...
