cmikefly Posted September 9, 2013 Share Posted September 9, 2013 - FOR SALE - COMPLETE OVERHAUL / NEW 300TDI I have a complete 300TDi that I have done a major overhaul on for a 110 project that will not go forward. I am planning on taking it back to the USA to sell but I thought I would offer it up here first. This would make the perfect engine for an older Defender for overland/expedition use. the only parts that I reused from the original engine are as follow: Rear timing cover (STC4095 with new LR FRONT cover fitted) Water pump bracket oil dip stick / pick up valve cover intake L/R exhaust manifolds (Machined flat and soda blasted) block (+20) connecting rods / caps main caps Everything else is new down to the nuts and bolts. All internal parts came from Turner engineering including NEW head (ported and polished), crank (Std), cam, pistons, lifters, pushrods, rockers, rocker shaft. All external parts are Land Rover or OEM with a few small parts being Bearmach. Injectors are new Bosh and the FIP is Bearmach overhauled (with bosh tag). 100amp LR alternator, NEW Garrett turbo, overhauled power steering pump, new LR water pump, and new LR sound deadening cover. all other pipes and hoses are new LR. (including the air filter, bracket, and intake hose) Also fitted is an oil filter sandwich adapter with oil pressure and oil temp sensor as well as fittings for Amsoil bypass filter. (feed and return as pictured) Additionally the block mounts, engine rubber mounts, and fuel filter lines are included. Motor is located in Abu Dhabi. Please contact William for more information or photos: 0504478013 [email protected] Link to comment Share on other sites More sharing options...
jacksonaw Posted September 15, 2013 Share Posted September 15, 2013 Nice job done, mate. How much is asking price, i have a colleague who drive defender and I can pass the word if he is interested. Link to comment Share on other sites More sharing options...
