nutercrack Posted April 12, 2011 Report Share Posted April 12, 2011 the windows are stuck and i am unable to put them up or lower them down what should i do Link to comment Share on other sites More sharing options...
xeus Posted April 18, 2011 Report Share Posted April 18, 2011 If one window you mean, then something must be broken inside the door and stuck in window rail. if two windows are jammed, then check the fuse, relay, multi relay (if any) or some loose connection. Link to comment Share on other sites More sharing options...
