car horn has stopped working
amy
when the car horn stops working what are the parts of the car that i should check if they stopped working before i replace the horn itself.
if i go to the dealers they will change the horn in first instance without looking for a way to fix it and charge me a whole lot of cash
please help
Car horn are the last thing to fail usually. Check with burn fuses (if any). Loose wiring over the horn back side. If they both are fine, get to electrician and have him check the current continuity to check power is coming to horn when you press the horn. If not then it could be horn switch inside the steering which is freaky.
If all three above things are fine, then you should change the horn that means horn is gone bad.
  • 4 weeks later...
