queen Posted January 30, 2012 Report Share Posted January 30, 2012 i dont have car manual nor service history so how do i find out when to change the timing belt? Link to comment Share on other sites More sharing options...
jayd Posted February 2, 2012 Report Share Posted February 2, 2012 a slight bent on the belt will say if it needs changing If it cracks on slight bent then it surely dose changing. Link to comment Share on other sites More sharing options...
LFA Posted April 19, 2012 Report Share Posted April 19, 2012 new models such as LS460, GS300, GS460, GS350, GX460, LX570, IS300, ES350, RX350 comes with a TIMING CHAIN, wherein it doesnt need any replacement at all. But for old models, as per manufacturing standard. timing belt should be change 150,000 KMS or 4 years. Contact your nearest dealership to check whether it was changed or not. Also, see the bearings such as the tensioner, pulleys and the water pump if there's a coolant leak Link to comment Share on other sites More sharing options...
shadow79 Posted December 15, 2013 Report Share Posted December 15, 2013 timing chains do not need any replacement but there are conditions to this statement only if you observe very precise and regular oil changes with good quality oils or manual recommended oil quality if not then chains also get cracked and then break at some point (i have seen broken chains at my workshop) Link to comment Share on other sites More sharing options...
elvis Posted February 3, 2014 Report Share Posted February 3, 2014 Belt every 100k and chain after 200k depending on the condition. Simple. Link to comment Share on other sites More sharing options...
