i cant close the door 100%
the rubber strip that protects the door which is black in color sometimes comes off due to age which is a very common problem in cars. this must be the same case in your car too so check if it is coming off or not.
  • 4 weeks later...
If the rubber is not the problem it is also possible that the door has incurred a dent. Have you checked if the gap is cause by something else or if it is the normal door and there is simply a gap because it is missing the rubber?
