sheetal Posted November 7, 2010 Share Posted November 7, 2010 hi, i have a mazda 323 which is a 2008 model, recently i have been noticing that the coolant is getting exhausted very frequently that is it is half the quantity in 10 days and have checked for leaks and have found none. as this is the only site in dubai for these kind of forums i hope u can help me or else i will have to go to a garage or the dealer which will nt be convenient for me. hope u will tc Link to comment Share on other sites More sharing options...
sandeep Posted November 7, 2010 Share Posted November 7, 2010 As from problem what looks like its a very minor leak which is not noticeable by eyes under the car. Take some free time and very patiently look in the engine bay nicely in following area: Lift the coolant bottle and see under bottle if there is green marks of coolant leakage. Check the hose joint on radiator bottle Check around radiator all sides Check the two hose that goes in and out of radiator under the clamp Check same two hose at other end that goes in and out of engine under the clamp If you can figure out where is thermostat sits, check around that area If you know where is temperature sending sensor, check around that area. I am sure either of one place you will find some minor leak with green imprints or wet marks. Link to comment Share on other sites More sharing options...
sheetal Posted November 8, 2010 Author Share Posted November 8, 2010 Thanks sandeep, will try to find on friday. Link to comment Share on other sites More sharing options...
