BmwDubai Posted May 3, 2012 Share Posted May 3, 2012 BMW Tightening Torques The maximum tightening torques are: Only applicable to shaft screws with metric standard and fine threads acc. to DIN 13, sheet 13 and nuts with height of 0,8 x d acc. to DIN 934 and only for a m total = 0.125 (screws phosphatized, screws untreated or galvanized. Lubrication condition: unlubricated and also oiled). For cadmium-plated screws or nuts (m total = 0.08 to 0.09) the tightening torque with screw material at the same level of utilization ca. must be 30% less than shown in the table. The values specified in this table apply to all screw connections conforming to the aforementioned conditions. Not applicable when using a different surface or lubricant condition on the thread, or if the height of the nut differs. Not applicable to necked-down bolts, self-tapping screw connections or to connections between parts made of different materials. Important! Maintaining specified tightening torques is vital for performing repair work to a professional standard. This presupposes that the torque wrenches required for this are subjected to a regular inspection. Approved torque testing equipment is listed in the catalogue of workshop equipment planning documents.bmw_torq.pdf Link to comment Share on other sites More sharing options...
albert Posted May 6, 2012 Share Posted May 6, 2012 Thats a very nice find and post Mr. Admin. Thanks a lot. Link to comment Share on other sites More sharing options...
