when to change the air filter?
You can try knocking the dirt from the surface by tapping the filter to any hard wall. But that will remove the surface dirt and not the dirt which is inside the fibres. And dont attempt to wash it as it may damage the air filter completely.
  • 1 year later...
I usually change it once a year. This is the time when I change all the filters in my car. However, I don't use my car on a daily basis so in case you are driving a lot you should probably do this more frequently.
