How can i remove & replace rear view mirror in Mecedes E350?
  • 3 weeks later...
Remove the overhead control panel control module and Pull inside the rear view mirror down at one side
FYI The inside rear view mirror is held by spring tension
Now disconnect connector from overhead control panel control module and remove inside rear view mirror.
For installation do the same thing in reverse order.
