jamal Posted October 18, 2013 Share Posted October 18, 2013 hi guys, out of the blue question stuck in my head. How does the braking system in mercedes cars like the SLR roadster enhance the performance of the car? Just something general i wanted to discuss. Thanks everyone. Link to comment Share on other sites More sharing options...
mufti Posted October 18, 2013 Share Posted October 18, 2013 the braking system is built into the trunk rim which allows an owner to enhance the performance of the car. You can basically test the performance enhancement system through this .. Link to comment Share on other sites More sharing options...
bensondxb Posted October 18, 2013 Share Posted October 18, 2013 Process of testing the performance enhancement system: - Insert key, turn the engine on, keep in park. - Access the air brake switch. Middle console below the air vent. - Slide it to "test" position - Release and let it slide to neutral - while you are operating the switch ask someone to help you watch the brake lights, they lit up during test mode. - Turn the switch to manual position to initialize the brake. Provides extra stability. - Move the switch to Automatic position for auto mode. This is an automatically initializing system which will activate when you are driving above 95kmph. - When driving trough poor conditions just set your performance to auto or manual and the braking system will initialize extreme angle for braking in emergency. - Change motor oil, air filter, fuel filter and sprak plugs if required. You car is now better. Link to comment Share on other sites More sharing options...
jamal Posted October 21, 2013 Author Share Posted October 21, 2013 thanks guys, i didn't know that these particular cars had a built in performance enhancement testing system as well! Benson i will give it a shot for sure. Link to comment Share on other sites More sharing options...
