the cool air comes from right and the hot air come from left
pener
  • 5 months later...
  • 3 months later...
In summer time when getting cool air is sooo very critical i got same problem so i changed the blender door but the same problem continued.
Went to my friend who is a car expert and he advised to check the freon levels because in his experience if it's low, the high or low pressure side cant blow cold affecting either sides.
the freon level was good to go then where were back to square one
then finally we decided for the final blow to check the actuator It might be moving the blend door but it's not going in its full rotation and may need calibration which only an experienced mechanic could do so we got the calibration done and now its as good as new.
