rajivc Posted March 1, 2014 Share Posted March 1, 2014 Hi Everyone I have mercedes GLK class from 1 year. Suddenly the AC is not working specially if its humid weather outside. Sometimes its really annoying as the UAE weather is really hot and one needs to have AC in their car. Can someone tell me what is the reason behind the AC failure? Link to comment Share on other sites More sharing options...
mahmoods Posted March 2, 2014 Share Posted March 2, 2014 May be it is because of the absence of refrigerant in the system. Sometimes if you have leak i the system, the refrigerant of the AC goes out as well which ultimately results in the failure of AC. Link to comment Share on other sites More sharing options...
garythomas Posted March 26, 2014 Share Posted March 26, 2014 It can also be because of the seal failure in the compressor. The compressor should turn when you are trying to switch on the AC. if not turning, then the compressor is failed. You need to get it replaced. Link to comment Share on other sites More sharing options...
rajivc Posted April 1, 2014 Author Share Posted April 1, 2014 Thanks people for your replies. There was a problem in the compressor. I took my car to the dealer, and they fixed it. thank you so much. Link to comment Share on other sites More sharing options...
