gafore Posted December 23, 2010 Share Posted December 23, 2010 my car's petrol tank is having some impurities. how do i clean it. or do i need a pro for this job. pls advice Link to comment Share on other sites More sharing options...
rozaanman Posted December 24, 2010 Share Posted December 24, 2010 You need pro to open it and rinse it and clean it. But bigger question is how you know it has impurities as its sealed from all side and you have no means to access to fuel which passes thru fuel filter. If you are experiencing fuel delivery issue when u hit full gas, it could be from fuel filter or fuel pump or some carbon in injector. Do these following cheaper fix before getting your tank open. Use wayne injector cleaner for 50 AED from emarat and add it in HALF TANK (not full) and drive at high speed (120) for 1-2 hrs. If still have issues change the fuel filter (another cheaper fix) If still have issues get your fuel pump checked (change if its not holding pressure or have leaking air pressure nozzle or rubber O ring) If not open fuel tank and get it cleaned and rinse with petrol. Link to comment Share on other sites More sharing options...
