zahoor Posted May 21, 2011 Report Share Posted May 21, 2011 the engine oil looks like needs a change but i got the car service done only 4 or 5 months back where i had all the oil changed then how could there be another reason for this Link to comment Share on other sites More sharing options...
jacksons Posted May 23, 2011 Report Share Posted May 23, 2011 Engine oil usually change from 3000 kms to 5000km if you serviced with mineral oil. If fully sythetic oil then it should last 8000kms 10000 kms. Oil has life per km not months, but if you drive too much short distance runs then its advisable to change it more frequent than oil manufacturer recommendation. If its dark, better change it before it do more harm. Oil is cheap and cost much less than one fuel tank cost here. Link to comment Share on other sites More sharing options...
