kevin Posted August 19, 2013 Share Posted August 19, 2013 Hey guys, I am having a small problem with my GPS system. I have a 2011 and got the factory GPS with it. I try to enter a specific street number but the system won't read that ... instead it will go to other numbers or codes which are far from the ones I am trying to enter ... Don't think this is a problem with the street numbers or the addresses I am entering but its like more of a technology problem. Any ideas what I should do? Link to comment Share on other sites More sharing options...
matt Posted August 20, 2013 Share Posted August 20, 2013 Have you tried to use voice recognition? Works for me and what I like the most about it is that it is faster to use instead of entering addresses. Either that or just that your GPS system has another city or place entered in it. Is your map software up-to-date btw? there have been a lot of developments in the UAE in the past two years so its a possibility that the street numbers have changed or something. Link to comment Share on other sites More sharing options...
abbey Posted September 13, 2013 Share Posted September 13, 2013 Last but not least you can try updating the firmware if this weird issue is system issue 100% sure, then may be new firmware (stable one) might able to help your Sat Nav common sense back. Link to comment Share on other sites More sharing options...
