gear oil is good
rader
Check all the oil info, my personal fav
2 - GEARBOX FINAL DRIVE - TRANSFER BOX
units ESSO API standards ACEA standards
BC3 GX 80W90 SJ A2
4HP14 - 4HP18 - MB3 automatic gearbox ESSO ATF D
Part No. 9730.94 (1) (3) - -
4HP20/AL4 automatic gearbox ATF 4HP20/AL4
Part No. 9736.22 (1) (3) - -
manual gearbox MA-BE-ME-ML-BA7-BA10 ESSO GEAR OIL BV 75W80 (1) (3)
Part No. 9736.41 specific to Peugeot -
405 x 4 transfer box ESSO GEAR OIL BT 80W90 (1)
Part No. 9736.19 GL5 -
(1) marketed by Parts Department in 2 litre cans
(3) never use any other grade of oil
units TOTAL API standards ACEA standards
BC3 TM 80W90 SJ/CF A3/B3
4HP14 - 4HP18 - MB3 automatic gearbox TOTAL FLUIDE AT42 - -
4HP20 - AL4 automatic gearbox - - -
manual gearbox MA-BE-ME-ML-BA7-BA10 TOTAL TRANSMISSION BV 75W80
(4) new formula specific to Peugeot -
405 x 4 transfer box TOTAL TRANSMISSION X4 80W90 GL5 -
(4) if another oil has been used, drain and rinse but Never Mix the oils
2 - 3 - REAR FINAL DRIVE
units ESSO API/PEUGEOT standards
conventional rear axle ESSO GEAR OIL VT (5) specific to Peugeot
conventional hypoid rear axle
with limited slip and 405 x 4 ESSO GEAR OIL BT 80W90 (1)
(5) if there is no ESSO GEAR OIL VT oil available, use ESSO GEAR OIL GP90 or GX-80W90 after emptying and rinsing the final drive, but never mix the two oils
units TOTAL API/PEUGEOT standards
conventional rear axle TOTAL TRANSMISSION TM
MULTIGRADE 80W90 (4)
TOTAL TRANSMISSION TM 80W90 GL5
with limited slip and 405 x 4 TOTAL TRANSMISSION X4 80W90 GL5
