kxkumar Posted December 31, 2011 Share Posted December 31, 2011 I am having trouble starting the my Peugeot 307 SW - 2006 model. The battery is just 4 months old. One mechanic says that there is a problem with the starting motor. Any other suggestions? Anywhere I can get a second opinion? Link to comment Share on other sites More sharing options...
bhushandxb Posted December 31, 2011 Share Posted December 31, 2011 Starting issue has three things that you need to diagnose yourself. Fuel, Air, Fire. Fuel: Check fuel filter and pump, easy way to check floor the car and see if response is instant and great then it cant be fuel issue. Also drive on highway at 120-140 and see car runs smooth then fuel is fine. Air: Check air filter is clean and Air flow meter is good. Fire: Check spark plug is good, HT lead is fine, Coil pack is fine. Link to comment Share on other sites More sharing options...
maadas Posted June 10, 2012 Share Posted June 10, 2012 My Car also Same Problem. I Drived it runs only 80 KMPH , So what i should do, No Garage Sees for Peugeot Any Suggestion Link to comment Share on other sites More sharing options...
antone Posted August 29, 2012 Share Posted August 29, 2012 see the fuel line is working correctly. there can be a malfunctioning somewhere that needs to be changed or fixed. Link to comment Share on other sites More sharing options...
junioc Posted September 1, 2012 Share Posted September 1, 2012 if the starter is not working then also you can have starting trouble. Link to comment Share on other sites More sharing options...
lionkini Posted September 5, 2012 Share Posted September 5, 2012 I am having trouble starting the my Peugeot 307 SW - 2006 model. The battery is just 4 months old. One mechanic says that there is a problem with the starting motor. Any other suggestions? Anywhere I can get a second opinion? when this happened once in my car the mechanic said its the alternator had to be replaced. Link to comment Share on other sites More sharing options...
dima Posted September 6, 2012 Share Posted September 6, 2012 really strange problem and we still dont know what the problem was. kumar can u tell us how this thing was resolved. Link to comment Share on other sites More sharing options...
premnath Posted September 11, 2012 Share Posted September 11, 2012 really interesting Link to comment Share on other sites More sharing options...
