how can i stop the squeaking noise from clutch?
when pressing clutch there is a squeaking noise that i hear.
Why and how i can stop it?
most likely what ur hearing is the thrust bearing. if it is the case, ur gonna need a new clutch kit. i had the same issue on mine and ended up replacing the clutch kit for the dealer. although the clutch plates were still fine, the bearing cannot be purchased separately.
since urs is manual i assume u have an RC.
ADAPT Performance - Power Unleashed
SOFTWARE TUNING & PERFORMANCE PARTS
www.adaptperformance.com
