Engine Vacuum Leak!
Hi Guys, my name is Cyborg. I was reading an article and i came across the word engine vacuum leak. Can anyone explain me more about engine vacuum leak?
Whenever there is an engine vacuum leak, always note that there excessive air entering in the engine which is causing lot of troubles in the engine. The idle speed becomes too fast whenever there is an engine vacuum leak. As mentioned before, you also experience stalling or rough idle in the engine. If the vacuum leak is very bad, then may be the engine wont idle at all. Also, sometimes one will experience misfiring or hesitation in the car whenever one try to accelerate more. All these are symptoms of engine vacuum leak. If you are facing any of these, dont ignore these signs and take your car for the vacuum leak diagnosis.
