car is not moving forward on D
The first thing you should check is your transmission fluid level. You may have a transmission line that is leaking fluid. Have you noticed any wet spots on the ground under your car?
If not then it must be some sort of connection failure with the transmission linkage. This may actually be fairly easy and low cost to repair, but you have to get the car to a mechanic to find out.
