nujer Posted July 26, 2011 Report Share Posted July 26, 2011 what should i do after the CV nut has been removed from the hub to replace the outer CV boot on a 94 Camry? Link to comment Share on other sites More sharing options...
troll Posted July 27, 2011 Report Share Posted July 27, 2011 The out joint can not be removed from the shaft in the older models of the Honda and to replace the boot on those you have to remove the inner boot and joint Then slide the new outer boot down the shaft to install it reinstall the inner joint and boot Link to comment Share on other sites More sharing options...
